Stationary Engines Discussion Forum
Wisconsin AEH (Taking off Shroud)
ACE
05-27-2004 13:23:22
Im parting out an AEH. I came to the shroud and it looks like I need to take off the flywheel first. It has a rope starter in front of the flywheel and I dont know how to take that off either. Im new to these engine(sort of) and I dont know the tricks of the trade yet. Can someone tell me the process of taking off the rope starter and the flywheel to get the shroud off. Thanks Ace.
Zira
05-27-2004 16:40:29
 Re: Wisconsin AEH (Taking off Shroud) in reply to ACE, 05-27-2004 13:23:22
The rope pulley screws on, with a normal right-hand thread. If you look behind the slot for the rope you will see the flats to put a wrench on. I think it takes 1-1/8", I use a 15" adjustable. You will need to stop the crank shaft from turning (not hard if the motor is stuck!). The flywheel itself is mounted on a taper. You are supposed to pull on it with one hand while striking the crankshft "smartly" with a babbit hammer to pop it off. I use a copper hammer sice I don't have a babbit one. Then you can take off the shroud. E-mail me off-line, I may be interested in a part.
ACE
05-29-2004 12:15:33
 Re: Re: Wisconsin AEH (Taking off Shroud) in reply to Zira, 05-27-2004 16:40:29
Thanks for the help. Im not able to get your email address. Tell me what you want or want to do to find it. Im new.
Zira
05-30-2004 11:28:29
 Re: Re: Re: Wisconsin AEH (Taking off Shroud) in reply to ACE, 05-29-2004 12:15:33
I might be interested in the top sheet metal cover, depending on price & condition. My e-mail address is zira, the at bellsouth.net
