Stationary Engines Discussion Forum
Fairbanks Morse ZC-52 engine trouble
Adam L.
10-17-2006 18:30:22
I am currently restoring a F/M ZC-52 and it runs perfect off of the start valve. When i switch it over to the tank, i have to fully choke the engine to keep it running and even then it runs very poorly. Does anyone know what might be the problem? I have checked and i do believe the line and needle valve seat are clean. Any help would be appreciated. Thanks! Adam
Tinker In TN
10-17-2006 19:36:02
 Re: Fairbanks Morse ZC-52 engine trouble in reply to Adam L., 10-17-2006 18:30:22
Bad or missing check valve at the bottom of the fuel line.
AdamL.
10-18-2006 04:24:15
 Re: Fairbanks Morse ZC-52 engine trouble in reply to Tinker In TN, 10-17-2006 19:36:02
i do have a check valve, it runs the same weather i have it on or not.How good of a seal does it need to be? I could not blow any air threw it! How good of a flow the other direction does it need to be? I could suck air threw it pretty eailiy! Thanks for your help! Adam
Tinker In TN
10-18-2006 18:23:02
 Re: Fairbanks Morse ZC-52 engine trouble in reply to AdamL., 10-18-2006 04:24:15
I'd check the fuel line and check valve very careully. Also the carb where the fuel line attaches. When you open the needle valve to the tank, you are closing the one to the starting bowl aren't you?
You'd probably get more answers by going to www.enginads.com, and clicking on the Smokstak board. Post your questions there. LOTS more engine guys hanging out on that board.
Adam L.
10-18-2006 19:10:37
 Re: Fairbanks Morse ZC-52 engine trouble in reply to Tinker In TN, 10-18-2006 18:23:02
I do close the start bowl valve. Thanks! I will try eninads.com. Adam
