YT Website Comments and Suggestions
Still the same error message...
Absent Minded F
05-29-2020 20:12:42
It says,"Due to a system problem, the post you replied to only will allow replies on Classic View. Your reply was posted on classic view if you receive this message while you were at the point of posting (versus previewing), so dont repost it. Most likely, the original problem has been corrected but the post you were replying to was created while the database was down. Return to Discussion Forums. Error is 22". I've tried logging out & back in on both devices & both views to no avail. 'Bout all I can think to do from my end. Not a complaint, just letting you know it's still happening. Also, there's a problem with people not being able to respond directly to my posts. One other thing. Both rrlund & minnie coonie have responded to the post on the AC board about the Fox chopper & their replies have only shown up in the last post column. Neither have been attached to the op.
Once again, just keeping you folks up to date with what I'm seeing. If you already know all this, my apologies for the redundancy.
Mike
