Restoration & Repair Tips Board
MTD circa 1995 riding mower won't start
1richard1
09-14-2005 08:00:20
Hi,
My 12 HP mower has started doing strange things-
It is stuck in park so it won't roll forward or backwards
When you turn on the ignition nothing happens. I traced the problem to a metal rod which engages a safety switch under the panel -front right side.
The rod misses the switch when you depress the clutch. If you line it up manually the mower will start. Any ideas on these things ?
Richard
rustyj14
11-08-2005 13:07:25
 Re: MTD circa 1995 riding mower won't start in reply to 1richard1, 09-14-2005 08:00:20
Try using several flat washers on both sides of the pin/bolt that holds the rod onto the switch. This should tighten up the connection. If that fails, splice the 2 wires together and it should start. don't know about being stuck in "park"! Didn't know they had "park". Mine only had a pin to pull out to keep it from rolling! That kept the brakes on.
xragman
09-22-2005 14:16:12
try this idea
find problem & fix it..
