Restoration & Repair Tips Board
3 PT hitch lower link point
53GoldenJubilee
08-29-2005 14:23:47
Hi guys,
On my 53 jubilee there are 2 studs or bolts the anchor the bottom links for the 3pt. The left side seems to be correct with no play in the stud but my right side anchor has lots of play and rotates freely , so freely that it cant be undone but it wont pull out and I cant take the right bottom link off the anchor. How is this supposed to be setup? Can anyone give me a diagram of inside the axle housing to show how this system works? thanks a bunch.
53GoldenJubilee
08-31-2005 17:52:46
 Re: 3 PT hitch lower link point in reply to 53GoldenJubilee, 08-29-2005 14:23:47
Thanks for the help guys, i got it fixed!
jwm
08-29-2005 18:05:43
It is held on with a nut on the inside of the differential housing. You will have to remove the axle trumpet to get to the nut. Torque to 150 lbs. James
53
08-29-2005 18:45:46
 Re: 3 PT hitch lower link point in reply to jwm, 08-29-2005 18:05:43
Thanks for the advice!
