drott bulldozer injection pump (help)
jeff jurec
03-12-2008 15:13:38
i have a drott bulldozer that i am trying to get running. the problem im having is that i cant get the injection pump to pressurize enough to open the injectors. i recently went through the pump but it still does the same thing. the motor on the dozer is good i just cant get it to start. the model of the dozer is 150k3 and is a drott, the engine is an international harvester as so is the pump. i really need to get this thing running so any input from you guys out there would be greatly appreciated. also the pump is a rotary style and i think the dozer was built between 1961-1964. thanks jeff
jeff jurec
03-12-2008 20:15:12
 Re: drott bulldozer injection pump (help) in reply to jeff jurec, 03-12-2008 15:13:38
thanks for the reply, its helpful to know that, however would anyone know the info on the roosa master conversion kit. the info on this pump is model#6c4088 serial #28620 international harvester pump the dozer is a 150k3 thanks jeff
george md
03-12-2008 19:44:46
Jeff,
IH quit supplying parts and sevvice for the RD pump many years ago,at the time they made available a conversion kit to mount a Roosa- Master in place of the RD pump . If that is a 150 IH loader ,the engine is a D282 and is also used in the 560 & 706 (some) farm tractor. Engine may turn slightly higher rpm in the crawler. There is one pump shop that I know of that is collecting all the Rd pumps he can find and stripping them for good parts along with making bushings etc . He is near Lancaster , Pa and trades as Conestoga Diesel .I used to see him at the Rough and tumble steam show at kinzers, pa.
george
J. Schwiebert
03-12-2008 17:25:17
When you say International rotary pump are you talking the IH model RD pump?
jdemaris
03-12-2008 15:38:05
How about some more info on the pump? If rotary, is it Stanadyne, AMBAC, Bosch, CAV, etc.?
jeff jurec
03-12-2008 18:33:21
 Re: drott bulldozer injection pump (help) in reply to jdemaris, 03-12-2008 15:38:05
third party image
i did forget to mention that this pump was manufactured by international harvester. also would like to know if it could be interchanged. thanks
jdemaris
03-12-2008 15:37:56
