john deere fire to points
alfred oxendine
02-18-2008 16:34:59
anyone know anything about fixing a john deere tractor that will not start
DaveS
02-19-2008 05:23:42
 Re: john deere fire to points in reply to alfred oxendine, 02-18-2008 16:34:59
You definitely need more info. From the name of your topic everyone assumes that it is a gasoline tractor and not diesel. That narrows it down to 3 things, Gas, Compression and Spark. Which one of these don't you have?
You will not have fire to the points. All points do is create a path to ground.
Is it a mag tractor or does it have a distributor?
old
02-18-2008 17:46:05
Need a lot more info then what you have given. Theres say 100 or more JD models out there and the answer might well be different on a good number of them
