Restoration & Repair Tips Board
HELP M18 spark plug stripped out!!!
1031D
05-29-2006 13:07:22
I have a John Deere 14T baler with a Wisconsin TFD engine on it, and I shot a spark plug right out of the aluminum head when it backfired. Does anybody make anything to repair this like a heli-coil, and can I do it without taking the cylinder head off?
souNdguy
05-30-2006 08:15:18
 Re: HELP M18 spark plug stripped out!!! in reply to 1031D, 05-29-2006 13:07:22
OLD is right.. pull the head to fix. While a heli-coil -might- work.. I'd wonder if it sealed good. My prefered choice of repair would be to drill and tap for a larger size plug, if you can get down to good metal for the threads.. or drill and bush ( yellow metal? ), then tap the busing, and use standard plug.
A good machinish could probably fix this.. never know.. might find a guy doing aluminum work that could weld up, drill and retap..
Soundguy
Bob
05-30-2006 13:04:58
 Re: HELP M18 spark plug stripped out!!! in reply to souNdguy, 05-30-2006 08:15:18
S.G.,
A good machine shop will have either Heli-Colis or Thread-Serts to repair the head.
The Thread-Serts are a solid insert, but they require drilling and tapping the hole larger than needed for a Heli-Coil.
souNdguy
05-31-2006 15:15:22
 Re: HELP M18 spark plug stripped out!!! in reply to Bob, 05-30-2006 13:04:58
Those thread serts must have been what I have seen before.. it looked like they drilled and tapped an OS hole in the head, and then installed a bushing that accepted the oem plug.. must be the same thing.
Soundguy
old
05-29-2006 19:44:05
They should have a heli coil for doing that but I would still pull the head to do that fix, reason is you don't want the shaveings in the cylinder to be eaten up by the piston/rings
