Case L-LA 9 bolt hubs
Just a g guy
01-05-2008 07:56:47
Hi guys what are you doing to adapt 9 bolt wheels to the L-LA CAse tractors. Thanks
Jim Pollock
01-06-2008 16:28:17
 Re: Case L-LA 9 bolt hubs in reply to Just a g guy, 01-05-2008 07:56:47
I made a set for a Case 600 that had tapered axles. Do the Case La use the same tapered axles?
Josh Wilhelm
01-06-2008 20:45:10
 Re: Case L-LA 9 bolt hubs in reply to Jim Pollock, 01-06-2008 16:28:17
I'm not certain that they are the same but they are tapered with one key way. The taper is what presents an issue.
Oliver Puller
01-07-2008 14:05:30
 Re: Case L-LA 9 bolt hubs in reply to Josh Wilhelm, 01-06-2008 20:45:10
I believe I had about $350.00 in making a set for a 600 case. The taper on the 600 is 1 inch per foot. If the la is different, all I would need is the size of the original wheel center on both ends of the taper.
trulyred
01-05-2008 11:59:05
I didn"t want weld on hubs so I had the cast center turned down at a machine shop. A dual rim reinforcement ring can be used for the pattern. Cost me $600.
