Case 730/830
SemoH
12-05-2007 17:17:36
What can a guy do to these gas engines to compete in an open class. Like bore and stroke and what ever else can be done...Thanks
casefarmer
12-07-2007 17:53:02
 Re: Case 730/830 in reply to SemoH, 12-05-2007 17:17:36
Bolt in a 504 case engine. Lazer cut the injectors, rev to 3000 rpm and get a 4 inch turbo,also inject water/ methanol. Should be around 500 horsepower for about $3000.
mEl
12-06-2007 03:38:37
I have considered this project and have always come to the same conclusion, build a four and you will be doing battle with the sixes, a 5.125 X 7.5 will give you 618 cid with a 4 cyl, 928 cid with a six cyl. I have never done a 5.125 but that is the number I have heard batted around the Case circles and 7.5 stroke is comfortable from my converasations with other engine builders. If I were going to build I'd obviously do a six. mEl
