Carb adjustments on H
Farmall H Pulle
07-25-2007 19:40:44
I have a Framall h that has been bored to 3 5/8 head milled and cam from lemmons. my problem is that i can't get the carb dialed in. The plugs are a nice light brown but when it going down the track and lugs it down it falls quick like it s running out of fuel. it has electronic enigtion and govner work done at lemmons. it wont blow any puffs of smoke out going down the track either. it has a number 25 vinture in it now. any help would be great.
42Farmall
07-29-2007 11:35:38
 Re: Carb adjustments on H in reply to Farmall H Puller, 07-25-2007 19:40:44
Have you pulled it before the engine work? That's still a little motor, you may not have enough horsepower to pull that gear.
Farmall H Puller
07-25-2007 20:19:16
Im running an eletric fuel pump at 7 psi. the carb is off of a 300 i beleave.
Drew
07-25-2007 20:16:09
Are you getting enough fuel TO the carburetor? It could be sucking the carb bowl dry after running for a time at full throttle and running the carburetor out of fuel.
