CORRECT RIM SIZE ?????????????
THUMPER S
04-10-2007 17:13:49
I NEED TO GET NEW RIMS I HAVE ASET OF 12.4X24 TIRES. I GUESS I COULD USE 10 IN. ,BUT MAY WANT TO TRY 13.6X24 TIRES , ASSUME A 10 IN RIM WOULD BE TO NARROW. THINKING ABOUT WIDEING OUT MY 8 IN . ONE TO 12 IF I EVER WHENT TO 13.6 TIRES ANY IDEAS. THAKS..... ....
CLIFF S
04-11-2007 08:53:20
 Re: CORRECT RIM SIZE ????????????? in reply to THUMPER S, 04-10-2007 17:13:49
Do you have a MIG Welder? You can cut the rim and put in a 4 inch wide by 1/8 thick strip and weld it back together.
t.r.y.
04-11-2007 15:50:20
 Re: CORRECT RIM SIZE ????????????? in reply to CLIFF S, 04-11-2007 08:53:20
dag on cliff that takes some time to do it right. I'm actually thinking about doing that with mine.9 to 12's I don;t know will see. Super busy right now how bout you. see ya
CLIFF S
04-11-2007 17:18:47
 Re: CORRECT RIM SIZE ????????????? in reply to t.r.y., 04-11-2007 15:50:20
The rims on the Su C that i Pulled NATPA with are widened 3 inches to 12 inch and that took 10 Hours to do the job! If you come to Washingtonville you can see the latest rim work i just finished on a Case 300 !
t.r.y.
04-12-2007 04:17:43
 Re: CORRECT RIM SIZE ????????????? in reply to CLIFF S, 04-11-2007 17:18:47
I figured as much. they looked wider than 9in. THats the really the only way to do it with the c rims with the brackets. Only other thing is buy 12 36's double bevel and weld in brackets. Either way it takes some time.
CLIFF S
04-12-2007 04:42:38
 Re: CORRECT RIM SIZE ????????????? in reply to t.r.y., 04-12-2007 04:17:43
Dubble Bevel will offset it too much to look like any thing! They do make Blank Rims, 11x36 only but there still better atha 9 inchers
