Carb mods
BlakeG
03-27-2007 20:34:33
I got this Marvel Schebler carb from a friend of mine, off of a 6600 combine, was wondering what, if any mods that are possible that i should do to it before using it on my 88 oliver with 340 cubes, or should i just rebuild it to stock, also this has the fuel shut off on the bottom, is there any way to get rid of this, as i dont need it?! thanks
Glen in TX
03-31-2007 07:00:52
 Re: Carb mods in reply to BlakeG, 03-27-2007 20:34:33
Check with JD parts for manual needle set and see if you can find Earl in IL on JD forum or here someplace. If that carb has larger throttle bore than stock one you had would think you'll want to do some manifold mods or blending.
