Case L puller project
skipp 33652
02-02-2007 07:14:25
I am trying to put a long stroke L together and need some advice have tried several different rod combinations and cannot get more than maybe 8.25" of stroke. I either hit the cam or go out of the left hand side of block .any advice on different angled cap rods with less than 2.75" journal I was really hoping to keep 2.75" would consider 2.5" or 2.625".I was hoping to get close to 9" stroke.Paul
Masseypuller
02-02-2007 12:56:43
 Re: Case L puller project in reply to skipp 33652, 02-02-2007 07:14:25
How wide are the stock L rod journals?
You could use a 2.5" MH44 rod bearing, which is much wider than an automotive 2.5" bearing. A 2.5" journal will hold rather well on bores up to 5.5" (especially at the 44 bearing width), but it depends on much rod width you can handle.
Also, what is your (block) deck height?
Regards,
Masseypuller
