CNC PLASMA
Daniel Gillespi
02-01-2007 18:49:57
Hey we just purchased a CNC plasma cutting machine from Tracker INC. My dad does alot of garden art type of work and I mostly fabricate parts and pieces for my tracotr hobbie. This machine is awsome. It can cut 4'x8' steel up to 3/4 inch thick. Custom work is available we are located in Louisa Va @ 1540 894 0288 ask for mike. We are hoping to bring in custom bussniess from this machine. Thanks
http://www.trackercnc.com/machine_4x8.htm
ChadS
02-03-2007 10:41:54
 Re: CNC PLASMA in reply to Daniel Gillespie, 02-01-2007 18:49:57
If it cuts aluminum,, you can remake factory covers to replace when parts are removed off puling tractors,, when factory replacements may not be available,, pto covers, belt pulley covers, governor housing covers, aluminum timing plates, rear engine plates,,, man the list is endless!!! Think about it! ChadS
DSK
02-01-2007 19:32:36
Does plasma work to cut cast iron? That would save alot of time over a grinder when putting a stroker crank in a 2-cyl. JD. Depending on the tractor, you often have to cut the crankcase wall through completely.
MN JD
02-03-2007 13:03:42
 Re: CNC PLASMA in reply to DSK, 02-01-2007 19:32:36
Yes a plasma cutter will work on cast iron. Used it to cut holes in my G.
MN JD
