Farmall F-20 Upgrades
GoobSD
12-01-2006 16:06:52
I know some people will say find a different tractor but F-20s are my favorite im dead set on using my F-20 for some fun at local pulls...I was wondering what are some upgrades i can do to it?? I assume some head work and etc for now...I was thinking maybe in the future building some type of a stroker motor for it?? Any info on that???
Earl-IL
12-01-2006 17:50:22
 Re: Farmall F-20 Upgrades in reply to GoobSD , 12-01-2006 16:06:52
I built a stroker 20 back in 1985 it ran good. If I recall around 60 hp. We also built a stroker F-30. Good running tractor. I can put you in contact with the owner of these tractors. He still pulls the F30. Jim Hutson built the last one for him. It has a center main.
randy hall
12-01-2006 20:23:49
 Re: Farmall F-20 Upgrades in reply to Earl-IL, 12-01-2006 17:50:22
earl. have you ever seen a hiesler head for an f-20?
have seen
12-02-2006 09:08:56
 Re: Farmall F-20 Upgrades in reply to randy hall, 12-01-2006 20:23:49
Randy, do you need one?
have seen them for a 20 but not a 30.
Earl-IL
12-02-2006 08:07:03
Hi Randy, No I have not. The 20 & 30 have a good head. You need to make compression with a dome type piston. Earl
GoobSD
12-02-2006 13:50:14
 Re: Farmall F-20 Upgrades in reply to Earl-IL, 12-02-2006 08:07:03
Is there a dome type piston out there for F-20s or something that would work?? I was thinking maybe better pistions and some head work on a 20 could help it out alot
randy hall
12-02-2006 21:46:38
 Re: Farmall F-20 Upgrades in reply to GoobSD, 12-02-2006 13:50:14
the high compression gas pistons are flat on top but they stick up out of the sleeve 5/16's of an inch.
