Farm stock class tire size
101jrWebberville
08-21-2006 06:49:31
I'm new to pulling and currently working on a Massey Harris 101 Junior. The rules for my local pull state that the tire size can be one size larger then original. I believe the original tire size for my tractor was 10X38. So this mean the max tire size I can have is 11X38?
Also would it be better to have taller or shorter tires?
39 A
08-26-2006 17:12:53
 Re: Farm stock class tire size in reply to 101jrWebberville, 08-21-2006 06:49:31
if you are talking about the local asphalt pull during the firemans field days, then yes one size over factory stock, so if you had 10 x 38 that is the old number, it then changes to 11.2 x 38 so one size over that is 12.4 x 38 remember you have to have wheelie bars they have to be 5" behind the hitch and no higher than 16" off ground. you should call Britton Moecel at (517) 719-5280. Who are you?
terry in mi
08-21-2006 19:13:23
Taller is usually better.
