1066 Turbo
Larry Markson
02-07-2006 19:15:20
What turbo would be best for me to put on my 1066? I plan on pulling it some but I want to still be legal in the farm stock class. Is the turbo from the 1466 the biggest one you can get and still be legal?
minnesota red
02-10-2006 12:53:35
 Re: 1066 Turbo in reply to Larry Markson, 02-07-2006 19:15:20
most pulls allow any turbo that will bolt to the factory mounts.
in that case i would shoot for a S-3 holset,bolts with stock bolt patern but is about the same size as a T-06.
ejr-IA.
02-10-2006 09:56:38
Ok on that turbo 3lm466 Part no.SDT 193876N Mfg.no is 193 876 replacement for IH TO4.Here's a web site that carries new ones with exchange old TO4 www.spencerdiesel.com they have a 800 number you can call.On the site go to IH 1066 then to turbos they show this turbo the man said 529.00 + core.
ejr-IA.
02-09-2006 13:08:22
Thats the type except it has the wrong exhaust flange for the up right elbow.If you get the one I'm talking about your exhaust elbow will fit right in the new turbo.Give me a little time and I will get you the right No.That was a decent price for that turbo the correct one won't be much more.
Larry Markson
02-09-2006 14:18:02
 Re: 1066 Turbo in reply to ejr-IA., 02-09-2006 13:08:22
Thanks man. I appreciate it.
Larry Markson
02-09-2006 11:19:04
Is this what I need??
http://cgi.ebay.com/ebaymotors/SCHWITZER-166151-TURBO-NEW_W0QQcmdZViewItemQQcategoryZ33742QQitemZ8000931752QQrdZ1QQsspagenameZWD1V
TONY JOHNSON
02-08-2006 13:15:37
get yourself a 13mm head for your pump looks stock.....doesnt flow stock
ej-IA.
02-07-2006 21:18:52
WHat you need is a 3LM 466 schwitzer or holeset its a stock replacement with more capacity and air flow.Much better than the TO4.
