Cam grinding ???
Big Rigger
05-14-2005 12:14:45
how do i know how much lift and duration to have put on it thanks
CrazyAllis
05-16-2005 19:52:02
 Re: Cam grinding ??? in reply to Big Rigger, 05-14-2005 12:14:45
Contact Custom Built @1 888 477 9369.You need to be able to tell him bore,stroke,compression ratio,extent of modifications,what they are,the RPM you expect to run,etc.He does good work and gets it done quick and back to you.
Drew
05-14-2005 20:09:06
What kind of tractor? What cylinder head....and has it been worked on? What RPM? What carburetor? What rocker ratio? These are just a few of the things your cam grinder will need to know.
