Carb For IH
Allen West
09-20-2004 14:31:35
I'm currently putting a Farmall 350 together for pulling,and need to know what is the best carb to run. My motor has new power crater pistons in a stock bore, .30 milled off the head and over sized valves in the head. I'm also running stock intake/exhaust manifold and electronic ignition.
ChadS
09-21-2004 07:36:30
 Re: Carb For IH in reply to Allen West, 09-20-2004 14:31:35
Rebuild, and rejet the one you have. Is it running? How much compression? 120-150psi, the 350 carb is fine with a jet size change. 150-200, step up to the M venturi. ChadS
