Case 900
Ryan
07-11-2004 08:55:35
Can any one tell me what years the case 900 was built, also can you tell me what it weighs, horsepower, and cubic inches. thanks
docjoe
07-11-2004 15:47:29
 Re: Case 900 in reply to Ryan, 07-11-2004 08:55:35
Ryan I have a 900 that i run the 5500 class with. It takes a serious diet to get there any questions? Ill be glad to help. Later docjoe from Mo.
Lamont
07-11-2004 20:34:16
 Re: Re: Case 900 in reply to docjoe, 07-11-2004 15:47:29
Are you running aluminum wheels? What all did you strip off the thing?
docjoe
07-12-2004 19:43:46
 Re: Re: Re: Case 900 in reply to Lamont, 07-11-2004 20:34:16
Lamont no i dont have aluminum wheels. I built light 20/38 steel wheels a home maid front axle and steering. you need to cut off the old steering from the transmission cover, weld on hubs remove hyd/pto rear section, disc brakes a light weight seat and so on. Like i said early on in this post a serious diet. I can send you some pictures if you like also can build you some parts. Later joe.
Jim M
07-11-2004 10:06:30
They made the Case 900 in 1957. 377 CID. about 78 hp. weighs about 8,000#. They made 900Bs in 1958 and 1959. The main difference was the injection pump on the diesel.
