CRACKED BLOCK
TK
05-21-2004 09:25:09
is there a certain epoxy that will fix a crack that is on the outside of an engine block. it is only cracked on the outside and coolant is leaking out, the crack is about a 1/16 wide by 3" long. don't want to take apart and weld. thanks
Broke 'n' Dumb
05-23-2004 13:23:52
 Re: CRACKED BLOCK in reply to TK, 05-21-2004 09:25:09
Using my grandpappy's advice, I'd tell ya to at least drill and pin the ENDS of the crack to keep it from spreading...then if you want to take a grinder and "vee" it out and either brase or JBWeld it, that's up to you.
Bill
05-22-2004 07:43:40
A good automotive machine shop can pin it shut which will also stop it from continuing to spread. They drill and tap small holes along the crack and thread in taperd cast iron pins works very good and not to expensive.
Sleddog
05-21-2004 10:02:47
We had a freeze crack like this. We used a hand grinder to vee it out. Fill with JB weld.Lasted thru time to rebuild.
Flogger
05-21-2004 10:56:13
 Re: Re: CRACKED BLOCK in reply to Sleddog, 05-21-2004 10:02:47
I had one that was spraying and I was able to take 2 hammers and peen it shut, and then JB weld it. So far so good.
maco
05-22-2004 12:23:30
 Re: Re: Re: CRACKED BLOCK in reply to Flogger, 05-21-2004 10:56:13
Product called "crack jack" get it at walmart. works excellent.
