CHAD S. question???
pullin 77
03-24-2004 19:08:40
Chad, i've read that you can make copper head gaskets for about anything, well how about a 54 oliver 77 with a 1550 head? price? contact info? thanks.
ChadS
03-25-2004 05:25:26
 Re: CHAD S. question??? in reply to pullin 77, 03-24-2004 19:08:40
Would not be hard at all. All I would need is a pattern to trace to use for your engine. ChadS
pullin 77
03-25-2004 16:20:28
 Re: Re: CHAD S. question??? in reply to ChadS, 03-25-2004 05:25:26
chad,
i have the old 77 head gasket,would this be the same for the 1550? if so i could send it to you.
thanks.
d.
ChadS
03-27-2004 08:04:09
 Re: Re: Re: CHAD S. question??? in reply to pullin 77, 03-25-2004 16:20:28
Only way to make sure, is to put the 77 gasket against the 1550 head and see what matches up on the head bolts, and water ports. Or just compare the 2 gaskets next to each other. CHads
