COMPRESSION ON M FARMALL
OLD M
07-17-2003 20:17:18
i HAVE AN M FARMALL WITH 4 1/8 PISTONS AND STOCK STROKE, THE HEAD HAS BEEN SHAVED .050 THOUSANDTHS.
CAN ANYONE GIVE ME SOME IDEAS OF WHAT TO EXPECT IN THE COMPRESSION AND HP RANGE.
dmp
07-19-2003 20:12:27
 Re: COMPRESSION ON M FARMALL in reply to OLD M, 07-17-2003 20:17:18
160-170
ChadS
07-18-2003 16:29:16
It depends on what kind of pistons you have. If you had a M&W type piston, (High dome, high compression type) You may expect about 65 hp with around 165 psi at cranking speed. Make sure your carb is in tune, A stock carb could be hiding 5-9 hp.
