Need More RPM's
'39 M Puller
07-24-2002 12:52:09
How do u get more RPM's.All informationis appreciated.
bud bareenie
07-24-2002 17:24:03
 Re: Need More RPM's in reply to '39 M Puller, 07-24-2002 12:52:09
from experience 99% of your problem is in the linkage. throw away the saw tooth throttle and get an m@w look a like open the govenor housing and adjust the lower screw out, alittle at a time!
put an rpm testor on it and run the govenor manually. after getting desired rpm's make the linkage work!!!
DaleLee
07-25-2002 12:07:18
 Re: Re: Need More RPM's in reply to bud bareenie, 07-24-2002 17:24:03
You can put two springs on the governor and get about 4200plus rpm I did but my whole engine is balanced As i go down the track i just open it up a little at a time till it really gets to luggin i wouldnt recomend opening it up all at once
