283 waukesha 2 peice head gasket
AGCOGUY
06-24-2006 22:21:19
Still looking for the gasket that goes in the 2 peice head on a 283 waukesha diesel out of an 1800 series A Cockshutt.
J Schwiebert
06-25-2006 08:50:57
 Re: 283 waukesha 2 peice head gasket in reply to AGCOGUY, 06-24-2006 22:21:19
You are very enlightning here. This must be a late 1800 A. Series. Right before I left for the good old army in the fall of 1962 I had to pick up an A series 1800 at the Columbus branch. They still had about 6-10 500 series Cockshutt tractors in branch inventory that came from the closed branch in Bellvue. We had also sold and delivered a new B series tractor by this time and had more new ones comming. I did't know any of the 1800 A series were sold as Cockshutts. Now with your gasket. Who have you contacted? (other than Agco). Also one of the 2 gaskets, don't remember if it is for the A series or the later ones will need to have some different holes punched in the gasket. It was one of those deals no body would accept the responsibility of who fault it was Waukesha or Victor that the correct holes were not all there. They were made to print but to the wrong print. I would like to see a picture of your A series tractor and the tractor and engine serial numbers as well. Thanks in advance. J.
AGCOGUY
06-25-2006 09:23:13
 Re: 283 waukesha 2 peice head gasket in reply to J Schwiebert, 06-25-2006 08:50:57
Mr Schwiebert ..thanks for all this info you given me here so far...The only place Ive tried for the gasket is through AGCO and I got one through them that they said would just need holes punched ,,but its not even close. Ive got some numbers from the head and block and tractor here:
Block 22358 found under gen
Head: 221602 104217-A 221 02 157-163-ASA
Tractor: 1800 Model 18-4254 Serial 121-252-886 I believe everything to be original..however the tractor was in alot of peices from the guy I got it from Thanks for any info..Ive got pictures ..do you have an email adres I could send them too??
