Bosch Injector Pump 550 Oliver Diesel
Eric Leslie
03-07-2002 13:26:51
I have and Oliver 550 which threw a rod, it has the Bosch American fuel system on it if anyone one is interested please make offer, In middle Georgia.
Thank You
Eric Leslie
Tom Ogen
10-08-2003 02:04:16
 Re: Bosch Injector Pump 550 Oliver Diesel in reply to Eric Leslie, 03-07-2002 13:26:51
I wish to purchase the following from you. Please send me your best offer for them.
1. Bosch Injector Pump. No. OX7223 P 4 2 Fuel mm3 - 398, RPM - 600 Qty: 1pc
2. Injector Atomizer ( Complete Injector Nozzles) Engine Model 2006 TTAG Qty required: 6 pcs
Please treat as urgent
Tom
Tom Ogen
11-10-2003 02:23:29
 Re: Re: Bosch Injector Pump 550 Oliver Diesel in reply to Tom Ogen, 10-08-2003 02:04:16
Qty: 1pc
Qty required: 6 pcs
Tom
ferrell freeman
03-08-2002 18:28:50
stanadyne what use to be the old roosa master pumps, these pumps always good service for lot of hours and some rough service ,the main thing is to keep the filters changed so the fuel is clean in the pump
ShepFL
03-08-2002 05:43:55
Eric - If the injector pump won't work I sure would be interested in any other parts you may want to consider getting rid of. I am located just across the GA line and 50 miles from Jacksonville. Drop me an email if you care to get rid of any other parts.
D13
03-07-2002 19:06:50
Do you have the number off the pump? The 'V' series (last before the Roosa change)requires a different front cover (or "filter support") than the "Z" or "Y" units, due to a pump camshaft change. I think mine is a Y unit but I'll have to look. I might be interested in it, and maybe the injectors and lines too. Actually I'd like the whole tractor but you're a bit of a hike from Michigan. That might strain the wife a bit much.
ShepFL
03-07-2002 13:33:23
Can this one be used to replace the ROOSA pump? Mine is not broken but sure wouldn't mind a spare. Looking for some other folks comments
Kerry
03-08-2002 11:53:03
 Re: Re: Bosch Injector Pump 550 Oliver Diesel in reply to ShepFL, 03-07-2002 13:33:23
The Roosa pump is still being made today and parts are cheap. The American Bosch pump, as I have been told, has not been made for years and the parts that remain are very expensive. I used to have the American Bosch and it quit working and I changed it over to the Stanadyne and man what an improvement. I would just stick to the Roosa Master.
ShepFL
03-08-2002 13:38:31
 Re: Re: Re: Bosch Injector Pump 550 Oliver Diesel in reply to Kerry, 03-08-2002 11:53:03
Kerry -
Thanks for that bit of enlightenment!! I have been dreading the day my ROOSA injector pump dies given the HORROR stories I have heard.
Breathing much easier knowing that ROOSA pumps available. Can you provide lead or contact?
Thanks
Kerry
03-10-2002 17:07:39
 Re: Re: Re: Re: Bosch Injector Pump 550 Oliver Diesel in reply to ShepFL, 03-08-2002 13:38:31
Pensacola Fuel Injection is where I got my pump. Great folks great price. Mike Goodwin is the person to talk to 800 622-5103.
Gary
03-07-2002 17:36:32
NO. you have to change timing cover and gears
