Oliver 60 wiring diagram
gbott
09-22-2015 08:32:10
Hello,
I am working on an Oliver 60 with the original 6 volt positive ground. I was wondering if anyone has a wiring diagram. It hasn't ran in two years and I want to ping out the electrical, so I can find the spark issue.
Thanks.
rvirgil_KS
09-22-2015 17:01:02
 Re: Oliver 60 wiring diagram in reply to gbott, 09-22-2015 08:32:10
If it hasn't run in 2 years and has spark issues
1. With switch on and well charged battery, you should see near battery voltage at input to coil
2 At output of coil you should see near battery voltage with points open and near zero volts with points closed.
After sitting for a time it is not unusual for points to develop a film on the metal surfaces that insulates them from making contact. I use a folded dollar bill and wipe it through closed points. If that does not clear the film, I use a piece of heavy paper like a grocery sack and moisten it with contact cleaner.
There could be other problems with old wires or corroded connections, but I would first make sure points circuit is working.
GBOTT
09-22-2015 08:54:13
If someone has one available, please feel free to email it to me.
Thanks.
SherryS
09-22-2015 09:15:04
 Re: Oliver 60 wiring diagram in reply to GBOTT, 09-22-2015 08:54:13
Is this what you need?
third party image
gbott
09-22-2015 09:27:06
 Re: Oliver 60 wiring diagram in reply to SherryS, 09-22-2015 09:15:04
It sure is. Thank you so much!!
