Order Ford 9N Parts Online
9N Limit Chains Revisited
Sean (TX)
05-02-2007 16:13:58
Finally got them hooked up. Didn't have to replace the lift pins on the bush hog after all...
Still might lower the wheel 1 notch to raise the deck a little more. Dragged a little today but not bad at all.
third party image
third party image
third party image
third party image
third party image
lonestarjeff
05-02-2007 20:59:47
 Re: 9N Limit Chains Revisited in reply to Sean (TX), 05-02-2007 16:13:58
Looks good Sean. How about the weather down there? We got hammered w/ 70mph winds & heavy rain, looked like a hurricane.
Jeff
Sean (TX)
05-03-2007 03:39:04
 Re: 9N Limit Chains Revisited in reply to lonestarjeff, 05-02-2007 20:59:47
Not sure about the wind. Rained like hell. Ill bet the river is up. Guess ill see when the sun comes up.
RP-40-9n
05-02-2007 17:43:54
sean, i only see one major problem, that ford 9n pullin something green, might end up with some weird disease that cant be cured. just kiddin! hey have you heard from tx in driftwood lately? RP
Sean (TX)
05-02-2007 17:48:44
 Re: 9N Limit Chains Revisited in reply to RP-40-9n, 05-02-2007 17:43:54
Its a sunshine mower not a JD. Not much green left but it cuts good...
Heard from him today...The broken bolt is out!!! I think the plan is to get her running this weekend!!!
Dell (WA)
05-02-2007 17:24:39
Sean..... ...ya didder good. Used a longer 3/4 toplink pin to hold the notched tie-brackets and then you SECURED yer excess limit chain-ends with zip-ties. I eventually put regular snap-links on mine 'cuz I kept runnin' outta zips (grin). I also used the inside length of the brushhog lower link pin to hold my limit chains tag-end. But yer solution will work too..... Dell, the ORC Safety Preacher
Sean (TX)
05-02-2007 17:55:10
 Re: 9N Limit Chains Revisited in reply to Dell (WA), 05-02-2007 17:24:39
That longer pin works good. I use it on my dirt scoop too.(standard 2 3/4 pin is not long enough for my dirt scoop.) I was thinking shackles on the excess chain. Using bailing wire for now. Had to get some mowing done. Glad I did to... cuz it is raining again...Will need to cut again next week...
1chano
05-02-2007 23:52:11
 Re: 9N Limit Chains Revisited in reply to Sean (TX), 05-02-2007 17:55:10
Cool
I use same thing on brush hog, box blade and tiller. One thing I did was paint the link that i use to brush hog black, paint wears off but it still keeps some on so you don"t have to count links when using it. I have the howard gears so I use 4ft tiller.
Sean (TX)
05-03-2007 03:41:20
 Re: 9N Limit Chains Revisited in reply to 1chano, 05-02-2007 23:52:11
Good idea about the paint. I was thinking the samething. I was thinking about using it on my rear blade to.
