I have contacted my dealer SEVERAL times regarding the quality of the Tisco parts they are selling, and I am buying (or returning). The response I have recieved is they are just as frustrated as I am because they keep telling their supplier and Tisco is not doing anything about it. You may support Tisco - and that is fine. However, on this project ALONE I have recieved a manifold that did not have flat mating surfaces, a head that was thicker than stock requiring me to go out and obtain longer non-standard studs, thinner than acceptable hydraulic pump valve chamber gaskets that required me to drive 20 miles to the nearest New Holland Dealer to obtaint the correct thickness gaskets so my pump could be installed, hydraulic piston o-rings that were too small requiring another trip to my New Holland dealer, incorrect bushing and seal sizes, and basically cheap ill-fitting parts from China and Tiawan (not to say you CAN'T get decent parts from these countries, but these weren't) that I had to modify or send back requiring my time, money, gas, and effort. If this is making great strides in their quality of parts - I guess I have been extremely lucky in the past. Don't get me on a roll here, I have never seen more CRAP from any parts supplier as I have from Tisco within the last year or so. My dealer was very appologetic and took parts back that I bothered to return, but I do not feel you should be "happy" getting crap that you have to either modify or trash brand new out of box! This is a perfect example - the jet hole was more than DOUBLE the correct size. I have three seperate sealed bags with the same part number and discription idle jet, but one is a different hole size than the other two. Who would suspect brand new parts FIRST in the troubleshooting process? How long did I dink with this problem replacing other parts in the troubleshooting effort because of INCORRECT PARTS! I am sure glad I wasn't a farmer requiring this fix to get a crop in (ok, I am stretching it a bit here, but you get my point). Once again - this is ONLY my opinion. Yours must be much better than mine. I appreciate your input and respect it, but feel much differently based on my personal experience. Sorry for the rant, that just hit a sore spot. Dan
