Hydraulic's won't stay up
Tom from Mi.
12-24-2006 04:31:41
Here's my problem,my 51 8N has good strong lift but drift's down after a few minute's. I've checked the fluid and it looks good,I've read that it's usually the lift cylinder rings leaking. Now my plan is to drain the old fluid, flush/clean out the housing, pull the lift cylinder, inspect and replace the piston with the Jubilee/NAA piston. Can I clean everything w/o dropping the pump and if not would it be worthwhile to rebuild that also? or "if it ain't broke don't fix it". Any advice for this greenhorn would be appreciated.
Bruce (VA)
12-24-2006 05:27:59
 Re: Hydraulic's won't stay up in reply to Tom from Mi., 12-24-2006 04:31:41
I had good luck cleaning the sump of my 50 sidemount when I replaced the lift piston; it was a lot easier to flush it out & remove the sludge w/ the top cover off than trying to do it thru the side covers. I"d say I got 95% of it that way. Dropping the pump will allow you to get it all; if you do that, replace the PTO seal while you"re there. I would not fool w/ the pump itself.
