Fix for sticking clutch
John.COLO
01-20-2006 08:13:02
Seems like there are always threads about Ns with the clutch disengaging erratically, if at all. Several things cause this; lack of regular use, gummy oil on the clutch plate from a leaking seal in transmission, moisture leading to rust. The correct solution is to split the tractor and repair/replace the issues. Participants on this site often look for shortcuts to avoid the work and expense involved in the full repair...block the pedal down, drag the brakes, drive tractor into a tree, etc. I've found a shortcut fix that works better than all others.
Brake cleaner sprayed on the clutch plate and flywheel will cause the clutch to function properly without sticking. First, the clutch must be disengaged. Heat is the best aid I've found. In lieu of a hot summer day, I direct the heat from my salamander jobsite heater at the bell housing with the clutch pedal blocked down. If the clutch doesn't spontaneously release I may need to start the tractor in gear and drag the brakes.
I drill a 7/32" hole into the bell housing on the right side about 2" back from the parting line at about the 2:00 O'clock position. Using the little tube supplied with the brake cleaner can I spray fluid into the compartment in the direction of the back of the flywheel. With the brakes locked on I do this with the engine running and the clutch pedal depressed, then ride the clutch for a couple of seconds. This creates heat and friction on the clutch disk and aids the clutch cleaner to work the guck out of the clutch disk. Be sure the drip hole in the bottom of the housing is open because alot of nasty stuff runs out. I repeat this time and again until I've used the entire can of cleaner. When finished I tap my 7/32 hole to 1/4"x20 and close the hole with a stubby machine screw.
This method has worked every time I've used it.
Best regards, tOTG
duey
01-20-2006 15:45:56
 Re: Fix for sticking clutch in reply to John.COLO, 01-20-2006 08:13:02
I've always been puzzled a bit by this "vast amount of work" it takes to split an 'N'. Seems like the first and only time I split my 2N, it was in two major parts in about two hours.... (and that was before Zane(?) talked about separating the steering sector to allow the hood and most wiring to remain in place during a split.)
What is your guess on time-to-split?
I was working in my garage with a cement floor and such tools as I had (no cherry picker or 'A' frame... changed the ring gear and now wishing I would have changed the front tranny seal, too, but that was in my 'pre-forum' days.
Regards, duey
LeeMo
01-20-2006 11:56:05
Yep. That's the same "fix" I've been using for a sticking oil fouled clutch on one of mine. It worked for about 2 years last time before I had to repeat it. The only thing I've been doing different is removing the starter and using a lighter to heat the spray tube on a can of carb cleaner so it'll bend to hit the face of the flywheel and clutch. Brake cleaner would probably be better for the clutch material than the carb cleaner I've been using.
Thanks for the post, John.
Later, Lee
uh . . . Dell (WA)
01-20-2006 08:46:11
John?..... ...ya know several years from now, this great N-Board is gonnna be gittin' questions from tractor neubies wondering what that unknown screw is doing, don't you? (grin)..... ...Dell
Jim.UT
01-20-2006 14:16:19
 Re: Fix for sticking clutch in reply to uh . . . Dell (WA), 01-20-2006 08:46:11
We'll call it the tOTG screw.
Dell (WA)
01-21-2006 00:44:21
 Re: Fix for sticking clutch in reply to Jim.UT, 01-20-2006 14:16:19
Jim..... ..tOTG screw, sounds good to me (grin)..... .Dell
Jim.UT
01-20-2006 14:12:56
Jim.UT
01-20-2006 08:35:40
John, it's good to hear from you. How have you been?
Last fall I bought a 9N basket case (literally) and parted it out. It was fun and I made some money. I wish I had the time to scour the back yards looking for more "inventory".
Jim.UT
