Exhaust manifold Donut gasket, should the tractor
gary
07-17-2004 17:29:29
Looks like it should have one, do get some leaking around it.
Gary
no . . . Dell (WA)
07-17-2004 17:56:33
 Re: Exhaust manifold Donut gasket, should the trac in reply to gary, 07-17-2004 17:29:29
Gary..... ..NO, the N-Exhaust DOES NOT USE a donut gasket. Your exhaust pipe has a bell-mouth to fit the exhaust manifold. A correctly installed manifold clamp is all that is required. (n.b....the manifold clamp has a rightsideup and can be inadverntly installed upsidedown). Checker out closely..... ...Dell
gary
07-17-2004 18:16:49
 Re: Re: Exhaust manifold Donut gasket, should the in reply to no . . . Dell (WA), 07-17-2004 17:56:33
How do I tell which side is up?
Gary
Jack - Illinois
07-17-2004 18:39:32
 Re: Re: Re: Exhaust manifold Donut gasket, should in reply to gary, 07-17-2004 18:16:49
The clamp I have has a smaller ID on the side that goes down (exhaust pipe) and slightly bigger ID on the up side (manifold). Just take the clamp off and hold the two halfs together and you can see the difference.
gary
07-17-2004 18:42:56
 Re: Re: Re: Re: Exhaust manifold Donut gasket, sho in reply to Jack - Illinois, 07-17-2004 18:39:32
Ok, thanx.
Gary
souNdguy
07-17-2004 20:53:07
 Re: Re: Re: Re: Re: Exhaust manifold Donut gasket, in reply to gary, 07-17-2004 18:42:56
If you still can't get it to seal perfectly.. cut a strip out of a soda can, and sandwhich it around the joint before you tighten the clamp down.. this did it on my 2n.
Soundguy
