NAA hydraulic
Jake in NY
01-29-2004 16:52:10
I'm not sure if this is the correct forum or not but I'll go ahead and ask this question anyway. We're redoing some of the hydraulics on our NAA and we have to replace a pin that rides on a cam that is an internal part of the 3 pt hitch. Does anyone have an idea as to what the part number might be? Our local dealer gave us a pin from some other model and it is way too big. The correct pin seems to be about 7/8" long, not certain about the diameter.
Thanks in advance for your help,
Jake
raytasch
01-29-2004 17:49:23
 Re: NAA hydraulic in reply to Jake in NY, 01-29-2004 16:52:10
If the pin is not worn half way through knock it out, rotate it 180 deg and reset it. It will last another 50 years.
ray
John Smith
01-29-2004 17:09:48
The cam follower pin you need is .309" diameter and 7/8" long. The Ford/New Holland part number is 374072S.
Jake in NY
01-30-2004 08:58:02
 Re: Re: NAA hydraulic in reply to John Smith, 01-29-2004 17:09:48
Hey thanks so much for your help. I just called the dealer and they even have it in stock. Now we just need to get it all back together.
Thanks,
Jake
