Bush hog chains
Patrick md. va.
12-31-2001 20:14:17
I thank those of you that responded to my last ?. As i read about hogging i have learned many new things that i want to try to make the job go better. I confused about using chains to pull or mount the hog. I think that i understand that the top link needs to be a chain,but do you use chain anywhere else?
parick md. va.
01-01-2002 14:01:33
 Re: bush hog chains in reply to Patrick md. va., 12-31-2001 20:14:17
Thanks for the advice. I understand now. Please be carefull mowing this summer!
Bill W.
01-01-2002 09:38:05
 Re: Re: bush hog chains in reply to Ed Gooding (VA), 01-01-2002 04:17:26
Ed: Please post Marshall's instructions. thanks.
asjahnke
05-03-2004 00:55:43
 Re: Re: Re: Re: bush hog chains in reply to Ed Gooding (VA), 01-01-2002 09:53:38
if you need longer lower lift pins, they may be purchased at a farm implement for a company with address www.speede.com. and ask for a catqgory 1 or 2 which ever size and ask for an adjustable 7/8in, lower link pin. you can orer them in the six inch lenght.which will give you extra inches when you use a stabilizer bar along with the adjustable chains , etc. good luck
Doggy
01-01-2002 01:34:33
ZANE THANG is a must!!!! Check Archives...
Cody
01-01-2002 00:40:48
Unless I'm misunderstanding you ... I would NOT recommend using a chain as a top link .
Salmoneye...Cody is correct...
01-01-2002 04:28:21
 Re: Re: bush hog chains in reply to Cody, 01-01-2002 00:40:48
DO NOT USE A CHAIN FOR A TOPLINK!!!
I can not emphasize that enough...
For Example.. Chuck (CA)
01-01-2002 05:47:33
 Re: Re: Re: bush hog chains in reply to Salmoneye...Cody is correct..., 01-01-2002 04:28:21
Whwn I first got my 'hog, I used a chain for my top link temporarily. I was cutting along when the front of the mower hit a small stump. Because the top link was not ridgid, it allowed the mower to somersault up. I stopped the tractor just before it flipped back, went in, changed my pants, and then waited until I got a ridgid top link.
Chuck (CA)
Fast Ed Ohio
12-31-2001 22:16:52
Do what Dell says , but please be careful ,you dont need to get hurt out there , life is to short.
Dell (WA)
12-31-2001 20:44:11
Patrick..... ..height limiting chains form a triangular leg from the 3-point top link down to the lower arm implement links. Chains allow you to raise the implement because the chain collaspses but will stop/support the implement from going any lower. I like 'em because I don't haffta keep watchin over my shoulder, checkin' on height while I keep watchin forward for obsticals to lift the implement over..... ..Dell
