Re: Cam follower pin rides short on lift arm cam
John Smith
08-09-2001 01:04:30
The cam follower pin is listed in the parts book as a 5/16 x 7/8 dowel pin but it's NOT. It is a hardened and ground dowel pin that is actually .309" in diameter instead of .3125(5/16). If you try to press a standard hardware store 5/16" dowel pin into your .309" hole, you can cause yourself some major problems. Don't ask me how I know that. The correct pin from New Holland is part number 374072S.
