Minneapolis Moline Tractors Discussion Forum
1953 MM GTB
Duke Adleman
05-04-2006 04:44:14
HELP! I am in desperate need of a set of heads for a 53 GTB. The current heads are casting number GE-30C. I don't know if this is interchangeable with other castings or not. Does anyone know where I can find some for rebuilding?
JK2
05-04-2006 14:19:31
 Re: 1953 MM GTB in reply to Duke Adleman, 05-04-2006 04:44:14
A GE-30C is tha same head as GE-30A, B or S (same as 10A4203). They have 5.55:1 compression ratio on a stock 403 engine. GE-30 M or Z (same as 10A4210) makes 9.1:1 compression ratio on a stock 403 & makes more HP for pulling. If you are going to lug it much & use it in the field, I would find a pair of one of the following GE-30E, F, H, W or 10A4209 with a compression ratio of 7.3:1.
John
ejr-IA.
05-04-2006 09:40:04
That head cross over to 10A4203 that is a very low compression head.Try to find a set of 10A4210 for the 403 engine they should be easier to find.If you find a set get the push rods to go with the heads.
raiken
05-04-2006 08:40:43
I have two MM heads, HC GE30A, they look good, will clean them to be shure. they are in OHIO
Curt Cooke
05-04-2006 05:39:51
Go to, or do a search and find, "the unofficial Minneapolis Moline Home Page". Go to classifieds and then to parts. Seems that heads are readily available.
Duke Adleman
05-04-2006 05:48:22
 Re: 1953 MM GTB in reply to Curt Cooke, 05-04-2006 05:39:51
I"ve been searching there also - no luck so far, but thanks!
Curt Cooke
05-04-2006 05:55:47
 Re: 1953 MM GTB in reply to Duke Adleman, 05-04-2006 05:48:22
You are probably aware that heads with different numbers will work. Like a 10A4209 or some such thing. I don't know what a GE30C crosses with, but it does cross with something.
Duke Adleman
05-04-2006 06:23:52
 Re: 1953 MM GTB in reply to Curt Cooke, 05-04-2006 05:55:47
Didn't know that for sure - thanks! I've actually sent the heads to AGKITS in New York. They're trying to tracks down some heads also.
