175 Steering
jogl
03-09-2008 14:51:23
I'm trying to tighten up the steering on our 175. The spline where the steering arm (the one that connects to the tie rods) is splined on to the main steering shaft is badly worn.
Any body have any good methods of fixing this?
I'm thinking about filling the spline up with epoxy or JB Weld and letting it set up.
Or maybe drilling and tapping holes up through the spline and screwing in bolts.
Any better methods?
I'll go ahead and get a price on a new shaft and steering arm for kicks, just to see what side of $2,000 the dealers are on.
Thanks,
JP.
jogl
03-10-2008 13:40:10
 Re: 175 Steering in reply to jogl, 03-09-2008 14:51:23
Thanks guys.
I JB Welded it. I'll let her set for a few days and see what happens.
I also priced out a new shaft and arm. To my surprise the dealer only wants $785 for the pair. $295 at Worthingtons.
I'll see how JB holds then pick up new ones when needed.
Good Day,
JP.
Yves Joseph
05-27-2008 06:11:44
 stering inner-ends in reply to jogl, 03-10-2008 13:40:10
Please send me a profoma invoice as soon as possible for two stering inner - end for a tractor ferguson 290.
Best regards
Eric in IL
03-10-2008 10:20:25
The J.B. Weld may or may not work, but I would try it. What have you got to loose ? I like the "kwik dry" formula and use it on alot on bearing races, even if they fit good. Can you remove any material at the slot where the clamping bolt goes ? Maybe,by using a larger angle grinder ? I dunno just a thought.
jbruce
03-09-2008 18:20:03
Not sure about that particular place, but the arms on top of the spindles on JD backhoes tend to wear out the splines. I take it off and cut thru one side with a torch then vee it out and weld it back. Shrinks it down until it fits tight. Usually have to drop it on fairly warm to get it all the way on. When it cools have never had one come loose again.
