135 Valve Clearance
DaveWall
01-13-2008 06:03:42
Quick one for you guys, finally getting my 135 back together
Can someone tell me what the valve clearance should be on the perkins AD3 152 engine?
Many Thanks,
Dave
Don_G
01-13-2008 08:35:45
 Re: 135 Valve Clearance in reply to DaveWall, 01-13-2008 06:03:42
As per my AD3-152 manual
.010 hot
.012 cold
Firing order 1-2-3
To set cold rotate the engine until cylinder no. 1 is on compression stroke and TDC mark is in the centre of the ispection hole.
Valves 1,2,3,4,and five are done first then rotate engine 360 degrees and do valves 5 and 6
Don
DavidP, South Wales
01-13-2008 08:31:52
Hi,
Cold 012" Hot 010"
Make sure you do not overtighten the tappets as you can split them easily. DavidP, South Wales
