Ferguson TO30 rear tire size
Perry
11-20-1998 12:42:43
Help. My Ferguson TO30 does not sit level. It
seems to be jacked up in the back. The rear tire
size is 12.4 x 28. Is this the correct size?
Thanks for your input.
Paul
11-21-1998 15:34:13
 Re: Ferguson TO30 rear tire size in reply to Perry, 11-20-1998 12:42:43
:I had the same problem. I bought new 11.2x 28 tires (Firestone) and my TO-30 now sits leve.
Paul
Rich Markham
11-20-1998 14:55:38
: Help. My Ferguson TO30 does not sit level. It
: seems to be jacked up in the back. The rear tire
: size is 12.4 x 28. Is this the correct size?
: Thanks for your input.
just took a look at my TO30, it has 11 x 28's on it.
Gerald
11-20-1998 17:23:04
 Re: Re: Ferguson TO30 rear tire size in reply to Rich Markham, 11-20-1998 14:55:38
: : Help. My Ferguson TO30 does not sit level. It
: : seems to be jacked up in the back. The rear tire
: : size is 12.4 x 28. Is this the correct size?
: : Thanks for your input.
: just took a look at my TO30, it has 11 x 28's on it.
11x28 is the same size as the more modern 12.4x28 I believe. You could check Miller Tire, Firestone, or Goodyear tire web pages for dimensions.
What are the front tires? My MF-135 was down in front with the factor 6.50-16s on the front. It has 14.9-24 on the back. With 11L-16 on the front it was level.
Right now it has 7.50-15 (from my JD4020) on the front and slopes down to the front a little.
Gerald
