Re: MF 65 gas utility performance question
Bob in Tennesse
09-28-2015 12:32:42
Larry, foot throttle or not the governor should respond to load whether it be pulling a hill or pulling a plow. I think you have a crank mounted governor that engages with forks on that engine. The governor balls flatten out over time and may need to be replaced. Unfortunatly with that Z engine you will have to remove radiator and crank pulley to inspect. But fortunatly, governor balls are cheap and the governor thrust bearing probably needs replacing while your in there. I did my MF-35 and a Ford 841 recently with good results.
