tluchterhandt
My mf65 steering has some play in the steering wheel before it actually moves the wheels. While I had it up on blocks awaiting hubs/bearings, I tried adjustments on the vertical pin that has the large nut and straight screwdriver slot, and also tried moving the adjustments on the turnbuckle type piece above the ram. Now after getting the tractor back on the ground it hesitates some turning to the right and is very difficult to turn to the left. Prior to me trying to adjust it the steering worked very easily, but only had play in it. I tried getting it back to the positions it was at prior but must not be even close. Any help would be appreciated. I would also like to know the title of the manual that would give step by step technique in adjusting steering as well as other repairs and adjustments. Does the manual go by sn?
I also wanted to add that there is no line or dipstick on the PS resovoir, how close to the top of cannister is full?
