Re: MF 65 Noises
DoubleR
04-02-2013 16:01:07
You don't have the 3 pt leaver in the Constant Pumping Position do you??? I don't have a 65 but I know my Massey will knock in the rear if that leaver gets put in that position and I have the outlet valve in the 3PT. position. I know the first time I did it I thought I had a big problem but now I know.
Traktor
04-02-2013 18:43:20
 Re: MF 65 Noises in reply to DoubleR, 04-02-2013 16:01:07
Good to know DoubleR.
Update: I refilled the hydraulic oil with fresh and cranked her up. Everything seemed pretty good with clutch in or out. Once I ran the rpm up I heard some noise - I tracked it to a worn out water pump that was hammering. From the seat it sounds like it"s coming from the transmission.
A new pump is on the way- Thanks for your support. I haved gained valuable information from all. I will surely have many more questions as I go through this 65. Masseys are a new breed for me.
