Starting still plugged in?
Ripper
01-27-2003 12:09:59
Will any damage occur to start up the backhoe with the block heater still plugged in?
Just asking because I have a habit of doing that.
Keep forgetting it's plugged in for the winter.
CJDave
01-28-2003 13:12:09
 Re: Starting still plugged in? in reply to Ripper, 01-27-2003 12:09:59
Actually, potential heater rod burn-out can be the result of a combination of things. First there is the possibility that the heater could actually run dry due to various cooling system anomalies. Then there is simply turbulent flow past the rod. When turbulent flow occurs, the round shape of the cal rod makes it almost impossible to get any heat transferred, even when water is present. In that case, not enough heat is wiped away and the rod overheats and self destructs.
BJ
01-27-2003 12:45:49
It all depends on the motor and type of heater if you have been getting away with it I wouldn't worry but just try to remember to unplug before starting anyways, I do know from my own experience we have a loader at work with a 903 cummins and you don't dare to start it with the heater plugged in as evidently the coolant pulls away from it and burns up the element
