JD A puller
Rman
12-25-2002 09:40:14
Would it be possible to take a block and head out of a 60 and put it into a newer A?? Just having thoughts about making one. Thanks for the help
BUDD
12-26-2002 13:40:18
 Re: JD A puller in reply to Rman, 12-25-2002 09:40:14
Rman;
I have a 49 "A" with a 60 head , intake and carb on it. It only dynos 36 HP and will lug down to 41 HP. The carb needs rebuilt though. The frame rails had to be cut just a little (if you do not know what your looking for you can not tell). I bought this tractor to pull and found out after the fact that it is not legal. So I am planning on going back to an "A" head this winter.
BUDD
Jeff
12-25-2002 12:24:05
Don't know anything about the block but my grandpa had a 60 head on a powerblock in an A and used it on the farm. Dad said some framerail work had to be done. Ran like a champ he said.
Roy
12-25-2002 17:38:27
 Re: Re: JD A puller in reply to Jeff, 12-25-2002 12:24:05
I put a 60 head on late styled A with a power block. Had to notch the frame rails for the head to clear. Its really no big deal to do.
