JD 70 Pistons
smoker
12-17-2002 17:19:49
Are the pistons in a JD 70 diesel the same as in a 720/730 diesel. Are the wristpins the same?
G Taylor
12-17-2002 18:03:36
 Re: JD 70 Pistons in reply to smoker , 12-17-2002 17:19:49
The 720/730 were treated to an improved shaped piston, six hole vs 5 hole injectors with a narrower angle, a 13mm injection pump vs 10mm, a separate pressure feed to the crank's center bearing, larger intake valves, late 720's and on had an anti-reverse cam shaft and higher pressure fuel transfer pump setting and a more crack resistant cylinder head. Stoke, bore, pin height, pin dia,deck height are all the same. The replacement piston is otherwise identical with the 80/820/830 piston except for how high the piston pin hole is bored in the piston.
