Gas neck broke off
Rman
06-18-2002 21:00:22
we have a 720 that gas neck from tank came loose from tank what is best fix we tryed jb weld held for while then came loose again thanks in advance mike
Clooney
06-19-2002 03:05:55
 Re: gas neck broke off in reply to Rman, 06-18-2002 21:00:22
Rman, about the only way to repair those broken tank necks is to clean all the fuel out of the tank, then purge it with steam or a commercial purging fluid, then fill it mostly up with water & solder the neck back in.
~If you don't have the means to get ALL the fuel & fuel vapors out, or don't feel comfortable with using heat on a potential bomb you could take it to local radiator repair shop as most of those shops are equipped to handle gas tank repairs.
