J.d 60 head and rod torque
rman
05-18-2002 20:08:45
could any one tell us rod and head bolt torque on 60 john deere thanks in advance mike
Ralph
05-18-2002 20:27:19
 Re: j.d 60 head and rod torque in reply to rman, 05-18-2002 20:08:45
Connecting rods 100 ft lbs, Cylinder head 150 ft lbs, block to main case 125 ft lbs. Manual says evenly and progressively to 150. Also tstellation, do not back off the to previous castellation. My mechanic took those in my A to 100 and then 150. Started and warmed up the engine and retorqued them to 150. Sequence in the manual is given as low center , top center left and right, bottom left and right, then the two on the outside left, and the two on the outside right. Left and right given as facing the head, which shouldn't make any difference.
gwh
05-18-2002 20:20:26
From JD-60 service manual "SM-2008" 150 ft.#'s on the cylinder head and 100 ft. #'s on the rods.
