730 Diesel injector pump trouble
Rob
05-07-2002 12:48:36
i can get fuel into the return line but none out the nosels on the pump and the pistons seem to just fall back and forth like they are pumping nothing is their a screen or something i am missing or do i need to have the pump rebuilt the tractor has sat for about 15yrs and i am new to 2 cyl diesels
DON
05-08-2002 08:09:51
 Re: 730 Diesel injector pump trouble in reply to Rob , 05-07-2002 12:48:36
ROB, SORRY I DIDN'T GET BACK TO YOU SOONER. HAVE YOU CHECKED TO SEE IF THE PUMP RACKS ARE MOVEING BACK AND FORTH WITH THE THROTTLE LEVER?,THIS IS THE SHAFTS UNDER EACH PUMP. IF IT HAS BEEN SITTING, THE FUEL GOES BAD AND GUMS UP, AND COULD BE HOLDING THE PUMPS IN SHUT-OFF. REACH DOWN ON BOTH SIDES WITH YOUR FINGERS AND SEE IF YOU CAN MOVE THESE WITH YOUR FINGERS. (HAVE THE THROTTLE WIDE OPEN).IF THEY ARE STUCK YOU MAY WANT TO HAVE THE PUMPS AND NOZZLES RUN. DON
