730 diesel bleeding trouble help
Rob
05-06-2002 14:22:32
i got a 730 diesel out of the fence row got it to turn over and can not get any fuel to the injectors but can get it to the fuel return in the tank when i take injector nuts loose and turn it over nothing am i missing a bleeder some plase
thanks Rob
DON
05-06-2002 14:57:18
 Re: 730 diesel bleeding trouble help in reply to Rob , 05-06-2002 14:22:32
When you take the nuts loose I assume you mean the lines to the injectors,you wont see much fuel at crank speed.Do you have the throttle pushed ahead to turn the pumps on? Don
Rob
05-06-2002 15:47:29
 Re: Re: 730 diesel bleeding trouble help in reply to DON, 05-06-2002 14:57:18
yes i have had the throttle in several places and can see the pumps working from time to time i think if the pumps are under the plate that the return comes through and i am towing the tractor with another. I have not got to the electrical system yet I am new to the 2 cyl diesel tractor
Rob
05-06-2002 15:45:10
yes i have had the throttle in several places and can see the pumps working from time to time i think if the pumps are under the plate that the return comes through i am new to the 2 cyl diesel tractor
